if its never worked. have you connected the waste hose to a spigot pipe under the sink . check that the blanking plug has been removed from under the spigot or in some cases you have to cut off the end so water will pass. The end of the waste hose has an orange plug in it on delivery if its still in remove it. hope that helps.
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
have you check your phone line also go in to the admin settings and re put your username and password back in it should sort out as i've had the same problem if it don't work get back to me thanks
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
