SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
SOURCE: 40 hp mariner outboard 2 stroke oil leak at
without seeing it in front of me its difficult to advise,i had a mercury but it wasnt oil injection so i iam not sure exactly how this injection system works but i should imagine its nothing more than a O ring thats perished or a copper washer needs cleaning with some wet and dry.I bought a new 4stroke mercury in the end because i got fed up with fuel consumption from the 80hp two stroke ,this four stroke 50hp will do about 12 14 nautical miles to roughly 6/7 litres of petrol at about 1200 rpm because iam only a sunday driver and the bumping on the waves makes my back ache unbearable,Well this is the land of fiesta /siesta /manaña --spain .Have a closer look and see where its leaking its only a mechanical pump running off the engine ,so it will have a push rod with some sort of diaphragm that pumps a tinysquirt of oil into the crankcase so it can mix with the incoming fuel ,nothing complicated
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
SOURCE: I have a 15 hp 2 stroke mercury outboard. When I
it is getting flooded ,dont ask me why, as im not there to check it out but if when first prmeing you stop pressing the bulb as soon as you feel any pressure at all, you will probably find it will start up straight away
