Sam4s er-290 is missing a line in receipt. Not faded, just totally missing. Happened overnight. Empty line all down right side of receipt. (example $21.32 will show $21. 2).
Is there ANY way this can be fixed by a factory reset? Or is it 100% purely physically the printer. Thank you.Is there ANY way this can be fixed by a factory reset? Or is it 100% purely physically the printer. Thank you.
Classic printer symptom. If the display shows correct price and printer doesn't, it will need work on the printer. RAM clear has never fixed this problem in all of my years of servicingClassic printer symptom. If the display shows correct price and printer doesn't, it will need work on the printer. RAM clear has never fixed this problem in all of my years of servicing
Thank you! ANY idea what this would cost on average to fix? I already contacted a shop, but awaiting their call back and want to see if they are in the ballpark for a fair repair price.Thank you! ANY idea what this would cost on average to fix? I already contacted a shop, but awaiting their call back and want to see if they are in the ballpark for a fair repair price.
It depends upon the problem. If it just needs the print wheel lubricated it will be cheap. If they have to replace the printer, could be a couple of hundred or moreIt depends upon the problem. If it just needs the print wheel lubricated it will be cheap. If they have to replace the printer, could be a couple of hundred or more
I wish you lived in So CA (I assume you don't). I never got a call back from the company I contacted. I'm not afraid to fix things. Is the printer easily accessible so I can lubricate it myself and see if that fixes it.I wish you lived in So CA (I assume you don't). I never got a call back from the company I contacted. I'm not afraid to fix things. Is the printer easily accessible so I can lubricate it myself and see if that fixes it.
You could try but it isn't always easy to get at them. If you remove the ribbon, you'll see that there is a small print wheel for each column of print that has numbers 0 to 9 on it. Gently try to move the wheel that lines up with the missing print and see if it is jammed. A small dribble of WD40 down the sides of the print wheel may help. Sometimes they split and then it is a full strip down or printer replacement. If you look on ebay, you might find an old cheap one that you could grab the printer from.You could try but it isn't always easy to get at them. If you remove the ribbon, you'll see that there is a small print wheel for each column of print that has numbers 0 to 9 on it. Gently try to move the wheel that lines up with the missing print and see if it is jammed. A small dribble of WD40 down the sides of the print wheel may help. Sometimes they split and then it is a full strip down or printer replacement. If you look on ebay, you might find an old cheap one that you could grab the printer from.
You're the best, Electroboy. Thank you so so much! This gal (me) has fixed my own car A/C, AND replaced my refrigerator condenser fan.. Maybe I'll be lucky a third time.You're the best, Electroboy. Thank you so so much! This gal (me) has fixed my own car A/C, AND replaced my refrigerator condenser fan.. Maybe I'll be lucky a third time.
It works! Maybe the wheel next to it was the one that wasn't spinning because I could only see four wheels in. We tried it again today and it works perfectly. How about that! Looks like the WD-40 worked itself in overnight.It works! Maybe the wheel next to it was the one that wasn't spinning because I could only see four wheels in. We tried it again today and it works perfectly. How about that! Looks like the WD-40 worked itself in overnight.
You can't post conmments that contain an email address.
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at http://www.cashregisterguys.com and if you are looking for ...
