A
ANDE Posted on Apr 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SHARP AR 5516 SHOWING RED HUMAN/STAR SYMBOL, please what could be the problem?
George Mclaughlin
Level 2:
Sergeant:
  • Sharp Expert 372 Answers
  • Posted on May 05, 2017
George Mclaughlin
Sharp Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128308
Points
839
That's a serviceman light and the star (circle of dots) means your machine is due for a developer change.
Testimonial: "Thanks for support. Please what of the triangle dots."
SHARP AR 5516 DIGITAL MULTIFICATIONAL COPIER MACHINE blinking toner light and without showing F2.
Question edited for clarity, 'sharp at 5516' to 'Sharp AR-5516'.
Remove the toner cartridge and clean the contacts on both the cartridge and the copier with alcohol. Tap the cartridge on both ends to settle the toner. Make sure you are using genuine Sharp replacements.
2answers
AR 5516 sharp printer is showing dotted triangle symbol
Just replace toner cartridge or refill the toner container with refillable sharp ar202 refill bottle or sachet. Remember to remove waste toner if you are refilling, right.
2answers
Red light display man and star
Ugay: on FixYa.com (older entries) they said,: Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button. Another guy said: "change the main charger because based on my experienced it has an arching problem "
another said: "Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser
107helpful
10answers
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
3helpful
2answers
20helpful
2answers
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
