Televison & Video Logo
Cheri Scott Posted on Apr 24, 2017
Need to program my spectrum remote to my 19" auria tv don't know how
Michael Wayne Mosley
Level 1:
Habit-Forming:
New Friend:
  • Contributor 14 Answers
  • Posted on Apr 24, 2017
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
14
Questions
Helped
1680
Points
51
Just Google spectrum remote instruction manual !! God bless !!!
I need the code for my Affinity TV so I can program the Spectrum Charter remote, they do not have Affinity on the list.
Here you go
Affinity TV codes for Spectrum universal remote controls:
3 digit codesfor UR5U-8780L/8790L, UR3-SR3M/SR3S, etc.
680
4 digit codesfor URC2060, Atlas 5 DVR/PVR, etc.
3577 3716 3717
4 digit codes (Cisco DTA)for Cisco DTA HDA-IR2 & HDA-RF2.2
4071 0881
5 digit codesfor URC1160, URC1060, M2067BX3 & Delta-3068
13577 13717 13716
https://www.eliztech.com/remotes/codelists/affinity-tv-codes-for-spectrum
I have a rca rcu404 universal remote that I can't get to work for a 32 inch auria tv
Auria TV 5 Digit Remote Control Codes
11423
10017
11265
10178
10856
11178
Auria TV Codes for RCA 3 in 1 Universal Remote = 12087
ON MOST REMOTES (Generalized):
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
No one buys Universal Remotes, they are so 1990s :>D You buy a facsimile remote which is an exact copy of the original, no programming needed and all the original functions.
https://www.google.com/search?q=32+inch+auria+tv+replacement+remote+control
Your search query is 'make model replacement remote control'.
I have bose cinamate home system i need codes to programe it to my spectrum remote
To program your Bose CineMate home theater system with the Spectrum remote, you will need to use the appropriate remote control codes. These rules vary depending on the model of your Spectrum remote and the specific model of Bose CineMate you have. Follow these detailed steps to program your Spectrum remote to control your Bose CineMate: Find the remote control code: First, you need to find the remote control code for your Bose CineMate system. Spectrum provides a list of remote control codes for devices on their website or in the remote control user manual. You can also try looking up specific codes online using the model number of your Spectrum remote and Bose CineMate. Turn on Bose CineMate: Ensure that your Bose CineMate system is turned on and in the proper mode for operation (e.g., TV or AUX mode). Enter programming mode: Press and hold the "Setup" button on your Spectrum remote until the LED indicator on the top of the remote turns on. Enter Code: Use the number buttons on the remote to enter the four-digit remote control code of your Bose CineMate. The LED indicator blinks to confirm the entered code. Test control: After entering the code, point the Spectrum remote at the Bose CineMate system and press various buttons (e.g., volume up/down, power) to see if it controls your Bose system. If it works, the program succeeds. Save the code: When the remote control works with your Bose CineMate, press the "Setup" button again to exit the programming mode. Now that the code is saved, your Spectrum remote should be able to control your Bose CineMate. Please note that not all remote control codes may work with all models of the Bose CineMate. If you can't find a working code, you can try the code search feature in your Spec
I need a remote control that will have for auria
0071 0101 0113 0152 0181 0236. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
1helpful
Need the codes for a auria remote to run a samsung tv?
go to www.remotecodlist.com or memorex.com or www.fitness.manualsonline.com
God bless you
My remote suddenly stops working? Auria EQ5588-tried new batteries
I also have an Auria EQ5588 with the same problem. The remote works when the TV is cold. But after the room warms up, it no longer works. Does anyone know where the IR receiver view port is? May just need to be better aligned with the view port.
Need codes for auria tv
what remote are you programming to this tv
My remote doesn't turn on my tv AURIA EQ5588, do I need a code
I also have an Auria EQ5588, the on screen prompts are the same as my APEX 32" 720p I bought over a year ago so either both are the same company or they share the same software. Both are Chinese Mfg. so who knows??? If your factory remote doesn't work call the phone # on the warranty page. There are universal remote codes listed on P. 6 of the owners manual if you are trying to code a cable or dish remote. There is also a reference to LG codes which are carried by Best Buy, Perhaps they can help you out if nothing else helps. The only glitch I've noticed is switch back to TV before turning off your blue ray player. If I turn off my Sony blue ray player and then go back to TV mode I get no sound, turn off the TV and restart it and it's fixed. Seems to be an issue between the brands. I'm pretty happy with the Auria since I got it for $700. Could have spent a lot more!!!!
Auria eq2288f 22" lcd tv
What has happened is that one or more of the back light tubes were broken in shipping, AURIA used hard foam packing and the TV could not handle the shock of shipping because of BAD PACKING from AURIA. if you call customer support they will tell you that is a power supply or inverter issue but it's not it's a broken bulb, you know they know about it because they will not tell you one or the other. if you open the Samsung screen (LTA400HM01) you will see that the bottom back light bulb is broken, why AURIA will not address this issue is beyond me. don't waste you time or money on power supply or inverter boards before you look at the back light bulbs.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
