Virginia Goodlaxson Posted on Apr 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Sharp UX-106 and when someone sends a FAX it automatically goes to voice mail instead. Why
George Mclaughlin
Level 2:
Sergeant:
  • Sharp Expert 372 Answers
  • Posted on May 05, 2017
George Mclaughlin
Sharp Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128197
Points
839
This has to do with your settings. The machine should be sent to auto receive.
When send out a fax, I got line error with my Sharp UX 106 fax machine. Thanks.
check that the connections are done properly telephone cable from wall plug goes into "line" input on fax machine and cable from telephone goes into "tel" on fax machine if this is correct then check that your telephone line has no problems ie. noise or line dead this is no good for comms to TX
2answers
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
1helpful
Cant receive faxes using sharp ux-108 model
If it sends ok, then it has probably been switched to "manual reception" or "telephone mode" from "automatic reception" -check manual on how to set.
Fax problem
Set the reception mode to A.M.
Set your answering machine to auto answer.
♦ Your answering machine must be set to answer on a maximum of two rings.
If not, you may not be able to receive faxes sent by automatic dialling.
♦ If your answering machine has a toll saver function, make sure that it will
answer by the fourth ring.
Below I've provided a link to your Owner's Manual. Best of luck!
Greg
Sharp UX-B700
5helpful
6answers
Manual for a Sharp UX-105 Fax Machine
I've got my old manual from a Sharp UX-105 machine. Does someone want me to mail it to them?
TD (in VA)
SHARP UX 105 Fax machine ....Problem
is this making a screeching, high ptch sound. If so that is normal when sending. as far as the rest yes that is normal.
Thank You,
Mikey
2answers
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
