Konica Minolta Bizhub c203 Copier Logo
Uchenna O Israel Posted on Mar 20, 2017
KM bizhub c 203 prints blank on yellow, I have tried replacing the y imaging unit, y laser unit, image transfer belt, all to no avail. How could it be fixed?
Abiodun Agunsoye
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Apr 07, 2017
Abiodun Agunsoye
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
5989
Points
17
Having done all that your Best bet is to check your Charger board, you could check for improper sitting and if that's not the case you should replace.
Dave Pomfret
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Apr 03, 2017
Dave Pomfret
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
21945
Points
37
Have you tried the High Voltage board that supply the voltage to the print heads and ITB. could be the print head is fine biut not getting any power to fire the laser and write to the drum
5 Related Answers
Inky
Inky Fingers
  • 705 Answers
  • Posted on Jul 23, 2008
SOURCE: Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Anonymous
  • Posted on Sep 15, 2008
SOURCE: Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
Paul schanzer
  • 85 Answers
  • Posted on Feb 16, 2009
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
Anonymous
  • 12 Answers
  • Posted on Apr 06, 2009
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Anonymous
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
How to remove white light appeared on artwork in konica minolta buzhub c454
If you have already replaced the charging corona, developer powder, and cleaned the laser unit, but the problem of a white light appearing on the artwork persists on your Konica Minolta Bizhub C454, here are a few additional steps you can take:
  1. Check the transfer belt unit: Ensure that the transfer belt unit is clean and free from any debris or toner particles. You can gently wipe it with a clean, lint-free cloth. If the transfer belt is damaged or worn out, it may need to be replaced.
  2. Inspect the imaging unit: Check the imaging unit (drum unit) for any signs of damage or wear. Make sure it is properly installed and securely seated in its designated position. If the imaging unit is defective, replacing it might resolve the issue.
  3. Perform a density adjustment: The Bizhub C454 usually has a density adjustment function. You can access this in the device's settings menu or through the control panel. Performing a density adjustment might help improve the print quality and reduce any unwanted artifacts.
  4. Check the print settings: Ensure that the print settings on your computer or the printer's control panel are appropriate for the artwork you are printing. Adjust the print quality, resolution, and any color settings as needed.
  5. Update the firmware: Visit the Konica Minolta website and check if there are any firmware updates available for your Bizhub C454. Updating the firmware can sometimes address software-related issues that may be causing the white light problem.
If none of these steps resolve the issue, it is recommended to contact Konica Minolta's customer support or a certified technician for further assistance. They will have specialized knowledge and tools to diagnose and fix the specific problem with your machine.
8answers
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Yellow background how can solve
Replace the image unit yellow with OEM you do not clean image units replace them. then next is the transfer belt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
P-27
P - 26 1st image transfer ATVC black failure
P - 27 2nd image transfer ATVC failure
P - 29 1 st image transfer ATVC colour failure
Check the transfer belt unit contact and that of high voltage board for connection and clean or correct the contact.
Change the image transfer belt unit.
Clean the sensor windows on the transfer belt unit.
2helpful
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
My konica Minolta Bizhub c250 is printing an image that is faded in sections and reprints very subtly in other sections where it should be white space. Can you help me fix this problem?
It could be either your image transfer belt that needs replacing, or your fuser unit. Check the transfer belt first, that's the most common cause for "ghost images"
Getting white streaks on black and color horizontally. km bizhub c352p mostly on screens, somewhat on solids.
sounds like you will need to have the transfer belt replaced. all images are developed on the four drums then transfered to the transfer belt then to the paper so if the image problem is coming out on all colors and black an white then the best bet would be to replace the transfer belt
1helpful
2answers
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
