SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
SOURCE: Binatone E3300 no dial tone, anyone have a manual?
USPJEH !Problem sa mojim binanotone 3300 je riješen. Napominjem da se kvar ogledao u tome da je na displeju telefonske slušalice bilo prikazano h b bez oznaka i da je stalno treperilo. Način na koji sam otklonio kvar je sljedeći: pristisnuti PROGRAM 1 0 i potvrditi zelenom slušalicom da se resetuju tvornične postavke, na centralnoj jedinici telefona-BAZA- pritisnuti tipku za registraciju, dr?ati tipku pritisnuti dok se ne čuje bip, nakon toga u roku od 30 sekundi ukucati PROGRAM, pa 1 6, nakon toga oznaku telefonske slušalice kod mene je bio slučaj da je to druga telefonska slušalica pa sam pritisnuo broj 2, nakon toga pritisnuti četiti nule 0000 i potvrditi zelenom slušalicom.
SUCCESS! Problem with my binanotone 3300 is resolved. Note that the defect was reflected in the fact that the display of telephone headsets hb without showing any mark that is constantly flicker. The way that I remove the defect is as follows: pristisnuti PROGRAM 1 0 and confirm the green headset that tvornične reset the settings, the central unit of the phone-BASE-press registration, keep the key press until you hear a beep, then within 30 seconds to type program, and 1 6, then the tag headset phone with me has been the case that this is the second receiver, so I pressed the number 2, then press četiti zero 0000 and confirm the green headset.
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
SOURCE: my smoothfitness 5.25 treadmill is stuck in the
Unplug your unit take the motor shroud off and you will see a circuit board (Motor Control Board) their should be L E D s on the board. Now plug your unit in and you will see these light up if you have a second pair of hands that can help you have them press you incline controls.
You should see one of these L E D s light up followed with a click of a relay this activate the incline motor some of these boards will have a 3 amp fuse to protect the board from damage , if you see a open fuse replace it with the same exact fuse. If it blows again either you have a shorted armature winding or the worm screw is frozen. I would call Smooth Fitness, depending wiether this was made by either Sports Art Fitness or Keys Finess they will direct you to theproper parties.
SOURCE: self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
