INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and then select 4:PlotsOff.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, stat plot , and then select 4:PlotsOff.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8. See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff.
The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:PlotsOff.
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf
to download the manual. On page 401, you will find the following:
INVALID DIM
• The ERR:INVALID DIM error message may occur if
• You specified a list dimension as something other
than an integer between 1 and 999.
• You specified a matrix dimension as something other
than an integer between 1 and 99.
• You attempted to invert a matrix that is not square.
If the message appears when you try to graph functions deactivate the
statistical plots. To do so:
Press [2nd][Y=] to access (STAT
PLOTs) Select [4:PlotsOff] then [ENTER]
That should solve your
problem. Post a comment to this thread if you still have trouble
graphing.If the message appears in another context, it sure
would help knowing the context of the error.
this happened to me as well. i looked it up and heres what i found: http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot" one of them is turned on so press enter and select OFF. this should fix the problem!
