SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
SOURCE: Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
SOURCE: toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall. This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight. If not, tighten firmly, but be careful not to overtighten. If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store. Cost About $1
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
SOURCE: setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
