Remove the lower freezer panel end then remove the rear panel . Remove the ice under bottom panel . Useing a hair dryer , heat the aluminum tray under the coils until you see the black drain hole . Continue defrosting the hole until free of ice . Could help useing a small screwdriver into hole . Even hot water into hole could help to clear . Once water will drain into hole , use a small hose inserted into hole and blow thru it to clear and obstruction in the line (line is inside the cabinet , unaccessable ) , Then find about a 14-16 gauge aluminum wire , aluminum fence post tie , aluminum ground wire , and insert it into the hole until resistence is felt . Wrap the top portion about 1 turn around the calrod (black) heating element and cut off the rest of the aluminum wire . The element will transfer heat to the wire during defrost , to keep the drain hole clear of ice .
