HP J3680
SOURCE: HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
SOURCE: Fax Problem
turn the printer on ...
unplug the power cable without turning the printer off....
press and hold # & 3, keep them on hold ....
while holding these two buttons put the power cable back in ... and wait for a few the screen to come up ... the screen may go blank ... use the power button to turn the printer on ... try to receive the fax ...
if it will not work then try # & 6 .... remember take the backup of phone numbers if stored on the printer as it ll erase the memory of the printer ,,,
SOURCE: fax does not connect on distinctive ring
Make sure that you have assigned it correctly. You should get a completion indicator or some kind of notification saying that the ring has been assigned to the specific location you ordered. if not, i will not be assigned correctly and it will go back to the default ring.. hope that helps ya:)
SOURCE: Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
SOURCE: how to set machine to receive incoming fax?
Receive a fax
You can receive faxes automatically or manually. If you turn off the Auto Answer option,
you must receive faxes manually. If you turn on the Auto Answer option (the default
setting), the device automatically answers incoming calls and receives faxes after the
number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
Here is the user guide: see page 55
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
