Konica minolta copier c280 showing error codes 3423, 3334 and 2451
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
SOURCE: Konica Minolta copier model C252 code C6102 any idea
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
