Patent (Intellectual Property) Law Logo
H
Harold Lilly Posted on Jan 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get a patent without an attorney? - Patent (Intellectual Property) Law
Werna Rosland
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 18, 2019
Werna Rosland
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
217
Points
1. Keep a Written Record of Your Invention
Record every step of the invention process in a notebook. Describe and diagram every aspect and every modification of the invention, including how you initially envisioned the idea for it.
Depending on the invention, you might also want to build and test a prototype. Document all of these efforts. Sign and date each entry and have two reliable witnesses sign as well.
2. Make Sure Your Invention Qualifies for Patent Protection
You cannot get a patent just based on an idea. You must show how your invention works. In addition, your invention must be new (or "novel" in the parlance of patent lawyers). This means it must be different in some important way from all previous inventions in that field.
Don't bother wasting time and money applying for a patent if it's likely that the USPTO's patent examiners will immediately reject your application. To learn more about which type of inventions qualify, see Qualifying for a Patent FAQs.
3. Assess the Commercial Potential of Your Invention
Applying for a patent is a business decision. Even without a patent attorney or the use of professionally prepared patent drawings, you may pay hundreds or even thousands of dollars in fees to file and obtain a patent from the USPTO.
Before making this investment, research the market you hope to enter and decide whether it's worth the outlay of funds. Or try to ask Peter from the https://fnblegal.com
4. Conduct a Thorough Patent Search
To make sure your invention is new, you must investigate all earlier developments in your field. This involves searching U.S. (and sometimes foreign) patents, as well as other publications like scientific and technical journals, to find related inventions.
Although patent searching is time consuming, it can be mastered with practice. Even if you decide to hire a professional later on in the process, you know more about your invention than anyone, so you are the best person to start the search.
You can start your research on the Internet, but might also want to visit a Patent and Trademark Depository Library. There, you can search earlier patents and get help from a librarian. For more information, see Patent Searching Online.
When you search, you will certainly find other inventions that are similar to yours. In your application, you should show how your invention improves upon or is different from these earlier developments.
5. Prepare and File an Application With the USPTO
When you file with the USPTO, you have a choice. You can either file a full-blown regular patent application (RPA) or a provisional patent application (PPA).
A PPA is not an actual application for the patent itself. Filing a PPA simply allows you to claim "patent pending" status for the invention and involves only a small fraction of the work and cost of a regular patent application.
All that is required to file a PPA is a fee ($65 for micro-entities, $130 for small entities, $260 for large companies); a detailed description of the invention, telling how to make and use it; and an informal drawing.
Then, you must file an RPA within a year of filing the PPA. If you do not, you can no longer claim the PPA filing date. Often, inventors file a PPA in order to gain quick credibility and perhaps attract investors. To learn more about why you might want to file a PPA, see the article Basics of Provisional Patent Applications.
Regular patent application (RPA): Filing an RPA, or regular patent application, starts the examination process at the USPTO, which is necessary for getting the actual patent. To learn what's involved in preparing a regular application, see Understanding Patent Applications.
John Roush
Level 2:
Novelist:
  • Expert 246 Answers
  • Posted on Jan 04, 2017
John Roush
Expert
Level 2:
Novelist:
Answers
246
Questions
113
Helped
43309
Points
119
How much would a patent cost?
The cost of obtaining a patent can vary widely depending on several factors, including the complexity of the invention, the type of patent being sought, the country where the patent is being filed, and whether you use a patent attorney or agent. Here are some general cost ranges for obtaining a patent:
1. Patent Search: Before filing a patent application, it's often advisable to conduct a patent search to determine if your invention is novel and non-obvious. A patent search can cost anywhere from a few hundred to a few thousand dollars, depending on the complexity of the search.
2. Patent Application Drafting: Drafting a patent application can cost anywhere from a few thousand to tens of thousands of dollars, depending on the complexity of the invention and the experience of the attorney or agent drafting the application.
3. Patent Filing Fees: The filing fees for a patent application vary depending on the type of patent (e.g., utility, design, or plant) and the country where the patent is being filed. In the United States, for example, the filing fees for a utility patent application can range from a few hundred to a few thousand dollars.
4. Patent Prosecution: Once a patent application is filed, there may be additional costs associated with prosecuting the application, such as responding to office actions from the patent office. These costs can vary widely depending on the complexity of the prosecution.
5. Issuance and Maintenance Fees: If a patent is granted, there are typically issuance and maintenance fees that must be paid to keep the patent in force. These fees can vary depending on the country and the type of patent.
Overall, the cost of obtaining a patent can range from a few thousand to tens of thousands of dollars or more, depending on the factors mentioned above. It's advisable to consult with a patent attorney or agent to get a more accurate estimate based on your specific circumstances.
2answers
Can you patent an improvement ?
You can go through this link - Patent Process Eagar and Martin Gold Coast Patent Attorneys
<a href="http://openad.in">openad</a>
Top Patent (Intellectual Property) Law Experts
Haider Zia
Haider Zia
Level 1 Expert
Are you a Patent (Intellectual Property) Law Expert? Answer questions, earn points and help others
