I tried googling but didn't have the patience. You know how LSA are mimited to 120KT (138MPH)? What about gliders? Can someone with a higher speed motor glider go faster for A to B flying (say, 150kt) without a private pilot ticket, glider rating only? Probably a really stupid question but I had to know. Not a pilot here so give me a break.
Gliders (soaring aircraft) are designed to produce high lift at minimal airspeeds, with minimal drag. That is, for all airplanes there is a lift/drag curve that dictates the speed that produces the maximum lift for the minimum drag. Sailplanes have only the thrust given them by gravity, to produce the most wing lift. Add to that whatever updraft they can find, and that's what's keeping them aloft.
To achieve this, they typically have long wings with a lot of what is called "wetted area" - the area affected by the airflow. Consider also that a major component of drag is a function of the velocity, and you discover that, just like in a car, it takes a LOT more power (thrust) to go 100 mph than 50 mph.
The LSA speed limit is a legal one. I am not aware of any country that imposes a speed limit on sailplanes (other than that pertaining to the airspace that they are in). But generally sailplanes are not going to give you high performance speeds. And what does give you speed limits on sailplanes is going to be Vne (the never exceed speed), determined by the structural strength of the wings. I think you will find that the indicated airspeed (IAS) for most sailplanes is relatively low.
