The DC10 was an excellent aircraft, with a long and successful service history. They are still flying in many countries, and in the US you see lots of them with the freight haulers.
There were, unfortunately, a few (very few) high profile crashes - which is probably what you refer to. The infamous "engine drop" issue was bad maintenance - not a problem with the aircraft design. And the Sioux City crash (pilot Al Haynes) was caused by a truly unlikely event that simply proves that even low odds can happen. [An uncontained blade failure on the #2 engine ejected "just right" (or just wrong) and cut the one small spot where all the control surface hydraulic lines came briefly together.]
The reason that DC10's are no longer in primary service is attributable to two things:
1. Older fuel hungry engines (3 of them), compared to the more fuel efficient twin engine design. And the changes to ETOPS regulations that now allow twin engine airliners to fly trans-ocean.
2. Certification of the aircraft with a three-person crew, in stead of the cheaper two-person flight crew common now. [The freight haulers get around this by cross training the loadmaster (only needed on the ground) to also be the flight engineer (only needed in the air).
