I'm trying to download VIDEO CAM SUITE 2.0 to my comp with Windows 10 home edition. Installing starts and I have a message: "THIS APPLICATION DOES NOT SUPPORT THIS OPERATING SYSTEM. THE INSTALLATION WILL BE TERMINATED." what should I do? Im not computer savvy .. but I have a so many memories on that camcorder that I can't afford to loose it. Any help is welcomed.
Depending on the output connections of the camera, it sounds like it’s well past time to transfer those memories on VHS to dvd or even better, to a USB device.
Look around for options depending on the format you wish to use.
Beware though that even DVD’s are on the ‘past it’ list. So look for a device that can connect to your pc via usb to your camera.
If that is not possible then I remember there used to be VHS players with a DVD option that you could record to from the VHS.
Failing all of the above, you can easily find someone that locally advertises this exact service.
Research, research....hope I helped a little.
Maybe you could set up a dual boot system using Windows 7, and install via that. Alternatively, is it possible to install using compatability mode ?
Try and get a later version of the video cam suit as the one you have may not be compatible with win 10
read the system requirements for the video cam suite 2.0 that you have and it will say win xp, vista ,7, 8 but if there is no win 10 mention , that is why you are getting the message
I have the same issue. Searching the net reveals many others also have the problem. It is such an unsettling issue, it is amazing how many commentators on so many different sites fail to see what the issue is as outlined by the OP.
