Televison & Video Logo
Joel Wendler Posted on Dec 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv model e470-a0 vizio turns off and on with the backlight and the vizio on screen logo is crystal clear on startup. No picture and sound other than some very very faint scrambled lines towards the upper screen. No dust very clean. No bulged capacitors. Wiggled most components. Unplugged rc connector with no change.
richie46
Level 3:
Top Expert:
  • Vizio Master 12,962 Answers
  • Posted on Dec 29, 2016
richie46
Vizio Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945287
Points
58151
T con board affects picture only. since you are having issues with both the picture and audio I would suspect the main board which deals with both.
2answers
How do I determine if I need a new power supply for my Vizio e470-A0 television that keeps blowing out the back light leds?
It uses a LG display panel & it has a common problem that burn out LED diodes.
To fix:
1. Change all of the strip at once & use new one.
2. Replace the power supply.
Hi i have a Vizio E470-A0 That wont turn on. I press the power button and it turns on for a second then fades or just cuts off.
Does your 12 volt remain at 12 after it shuts off or does it drop to 0?..This model was known for issues with the LED lamps themselves but Ive seen a number of sets where the LED's were fine and it was the power supply or main boards bad
Vizio E420I-A0 Black Screen
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Vizio E470i A0 Blank Screen No Backlights How to Test Power Supply...
Testing TV Backlight LEDs
Testing tv backlight leds EsBuzz net
http://www.badcaps.net/forum/showthread.php?t=41334
I have a vizio 470-a0 that is dark and the back light blinks every 5 seconds
The front LED light that shows whether the TV is on or off will flash so many ... press and hold the power button for 5 seconds upon plugging the TV in. ... The flashing code I got meant the power supply was bad.
1helpful
2answers
My screen is flickering on and off on Vizio LCD TV? I was wondering if it was the main board or the T-Con board.
Flickering can be either with the fault to its back-light inverter or with its main power supply regulator board.
I have a 32 vizio e320-a0 with a black screen with sound
probably the tv have problem with its back light, you have to check and replace the led driver. Che the video to more about back light.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
www.electro-medical.blogspot.com
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
