I can access all the printer utilites and when I print the job shows up in the printer queue and when the blank page has printed out the queue is emptied. Running MacOSX10.6.8 Printer is plugged directly into the wall socket, not through power strip.
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
SOURCE: My HP Deskjet F4580 won't print. Print jobs go
plaese folloW the instrutoion mention from the below URL and try
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=3944758
still dose not work then try this url mention from the bellow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669384&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361419&cc=us&lc=en&dlc=en&product=3944758
if still the issue is not resolve then contact hp tollfree number 1800-474-6836 they will replaced the printer if the warranty period is there.
hope this should resolve your problem
thanks
regards
HAMID
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
Hi Marjorie Kemp, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
can you find a clean print head option try this three or four times and fill us in on if this helped. Was it working before and has just stopped working ?
Did do the clean print head. No change.
I haven't used this printer recently so it could be the printer is kaput. I also read some advice that said if I can't print a test page (I get the same blank page when I try to print test page) there is a hardware problem with the printer.
