SOURCE: tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
SOURCE: I have a UJ 420 infrared remote control helicopter
Have you checked for any hairs or debri trapp-ed on the rotar shaft
sorry have to ask the silly questions check for voltage at wire terminals
some of the controls have automatic kill switch should they become binded up with something check that rotor is not installed to deeply on the shaft
could also be a short circuit in the remote itself good luck James
SOURCE: We broke the tail rotor
Hi munozcowan,
What you need to do is to use your email account to contact [email protected] and give them a description of your problem.
They are probably going to have you go to http://www.iwaveaudio.com/support.asp and fill out an RMA request which is just your address and the like.
I went through this and my RMA request was denied because I did not have a reciept to attach to the form as I had recieved the Copter as a gift.
I sent them another email saying that I just wanted a parts manual to order from but have not heard back from them.
Have Heart! it is my thought that if you do have a reciept, they may give you an address to send the machine to for repair or possibly send you a replacement.
SOURCE: The tail rotor on my
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
SOURCE: We just bought a 3.5 channel gyro 339 metal series
Same Happened to me you have to push the lover rutter down until you hear a snap all that happened is the rutter came off the gears it might need a little force but it worked for me hope i helped
