If you have a smart phone, many of the remote apps will work for peripherals such as these. If you want more detailed information, I would suggest hitting the link below. It's the manufacturers online owners manual. Often, your TV remote can also be programmed for additional devices. The manual below may offer the code necessary for this process. Good luck!
Power ON with NO disc inside:
Press PAUSE on the remote-control
Press 3,1,4,1,5,9 in sequence using the remote-control
Press 0 on the remote to select Region Free
Press PAUSE again to save
Power OFF then Power ON.
Done.
Looks like you only have composite out (yellow, red, white RCA cables) from your DVD player. If you have a newer TV, check to see that you have composite as an input choice.
1.Switch on the DVD player without any Disc inside
2.The screen should display 'no disc'
3.Eject to open the DVD tray
4.While the tray is open, press the 'STOP' button then hold the 'ENTER' button for 5 seconds
5. A new screen will appear (Regional Management Test Code) which will allow you to change the region code using the up and down arrow keys on the remote control.
6. Change the code to '0' and press the PAUSE key to exit
