I get the E message when using the print function.
SOURCE: info
SOURCE: my texas instruments ti-30Xa doesn't turn on!
It has a solar battery. It has to be in the light, either sun light or artificial light to operate. HOWEVER, if the battery is shot, it must be replaced. Take your calculator to any radio shack store and ask them to test the battery for you. If it is no good, they will be able to replace it for a fee.
SOURCE: texas instruments TI 38 PLUS USAGE
Here is the link to free downloads of TI graphing calculator's guides.
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=17
Enjoy
Hope it helps
SOURCE: how to clear the memory key on Texas instrument
Your calculator has 3 memories (M1, M2,M3)
To store the number 170 in M1 use 170[STO]1
To recall a number from M1 use [RCL]1
To add a number to the content of M1 [2nd][SUM]1 (adds displayed value to contents of M1).
[2nd][EXC] 2 exchanges the value already displayed with the contents of M2:
To erase (clear) a memory register, just store 0 in it.
Hope it helps.
SOURCE: texas instruments ti-86 screen problem
The TI-86 uses a very small, very thin ribbon cable to connect the display board to the LCD. The cable is about 2.5 " wide and about 4" long, and is only slightly thicker than a piece of paper but has about 40+ leads buried inside. Over time the leads will break at the folds (there are at least two folds in this cable to fit it down inside the case). There is no cheap solution to fix this problem. You might have some "Mr. Fix-it" try to fix it, but he will tell you to throw it away after he renders it completely inoperable. The calculator uses two Torx bit screws at the bottom of the case (T-6 size) so you will have to get the correct screwdriver to open the case. Save your money, sanity and time and use it till you can't stand the missing lines and throw it out. Even the data cable looks like it is glued down so if it lifts off after being cooked or frozen a couple of dozen times in the back of your car you can't fix this.
