Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
Kayla Bates Dickinson Posted on Sep 24, 2016
Konica Minolta 4690MF - Paper jams in ADF
Simply cannot use the ADF without a jam everytime. Grrrr.
Martin Haba
Level 1:
Habit-Forming:
New Friend:
  • Contributor 36 Answers
  • Posted on Oct 01, 2016
Martin Haba
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
36
Questions
0
Helped
20867
Points
70
If it physically doesn't go through, try to push a heavy stock card or decent thick laminated paper and try to feed it through. There maybe a mylar (plastic sheet) flipped backwards or a piece of debree stuck in paper path of your Document Feeder. This may resolve 80% of issue.
The rest could be broken sensor flag (actuator) or dirty sensor that is not reading the paper passage (or it the sensor is faulty all together)
The amount of staples, paper clips, Bluetag and other junk I pulled from ADF over the years..Bucket loads :)
Good luck.
Testimonial: "Thanks for stepping up to answer this, Martin! I'm going to have to figure out where the sensor is. Would you be willing to say about where I should be looking and the characteristics of what I'm looking for? Does the sensor have a lens? The paper begins to feed and then stops, resulting in the 'paper jam error'. I'm the only one that uses the adf and am very careful about staples, etc, so I doubt that is an issue. Any additional thoughts you might have would be most appreciated!"
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Adf paper jam konica minolta
again sir/mam What model adf raise and look under what model copier???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica 4690 mf switchback jam
check the sensor might be dirty
Konica Minolta adf is not currently available
what model number of the copier
Konica minolta 7416MFG saying paper jam but i removed sll the papers without tearing
the door or cover is not properly closed or it may still have piece of paper inside it.
When trying to fax I get an error "open adf cover"...
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Ongoing jamming/misfeed problems
feed rola in adf u have to change to roles from c350
part nr
4582-3047-01
1helpful
3answers
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
