Manley Mad Science Bubble Experiment Lab Logo
e
emma martin Posted on Sep 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is a control and exserpmental group
Need a better understanding about control and experimental group
Mark Schmit
Level 3:
  • Master 1,915 Answers
  • Posted on Sep 15, 2016
Mark Schmit
Master
Level 3:
Answers
1915
Questions
0
Helped
754084
Points
7967
A control group is one that is used as a baseline and is not exposed to the test itself. The experiment group is the one actually testing to see if something changes. For instance, if testing a ****, the control group would be given a placebo (fake inert ****) while the experiment group is given the actual **** being tested.
1helpful
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
What is the experimental group in science
For example, if they want to test a variable, the experimental group is given the variable and the control group does not get it. This way, the variable can be compared to a known reference.
What is a experimental group
An experimental group is used in an experiment to test a variable. It is the group to which the test variable is administered.
What is the dependent variable, independent variable, the control group and experimental group?
dependent variable: fear/no fear
independent variable: cymbal/no cymbol
control group: the group with no noises
experimental group: the group with noises
Cannot connect to the internet on the Toshiba Netbook. Has very strong network signal.
Troubleshoot the issue by identifying the ip address that your computer has. May it be wireless or local area connection. Check IP Address thru command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection and local area connection group by scrolling up/down.
NOTE: ignore highlighted physical address.
If the ip address is 169.xxx.xxx.xxx, this is an invalid ip address. Contact Internet Service Provider. If the ip address is 192.xxx.xxx.xxx, click start and open control panel. then open internet options. click on connections tab. click on lan settings. Make sure no tick box checked. All set your anti virus' firewall settings to default. Then try browsing.
I hope this works for you. KINDLY REPLY IF FURTHER ASSISTANCE NEEDED. Good Luck!
Mongkey
"Understanding explains better..."
2helpful
2answers
Ip adress of my router
Check IP Address from command prompt or DOS.
· type "cmd"
· locate wireless connection group by scrolling up/down. ip address should be listed in wireless connection group.
mongkey_21.jpg NOTE: ignore highlighted physical address.
I hope this works for you. Good Luck !
Mongkey
Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
18helpful
4answers
Codes for universal remote control
i have the list of codes for the 40085 HTFB, but no instructions. (I assume this is because it's LIDL - their store security is a joke). Which code do you want? And do you want to swap for instructions on how to set up for a specific TV?
Top Manley Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Manley Toy Expert? Answer questions, earn points and help others
