Televison & Video Logo
Tammy Coburn Posted on Sep 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need manual for samsung tv
Model code# PN50B55OT2FXZA Serial NO. AUMJ3CQ5708515N Version S602
Darryl Mannthi
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Sep 01, 2016
Darryl Mannthi
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1961
Points
39
bigdawg7299
Level 3:
  • Master 2,559 Answers
bigdawg7299
Master
Level 3:
Answers
2559
Questions
0
Helped
556879
Points
7776
Try the samsung website for your country
How to fix single green vertical line on Samsung TV
Easier to buy new set then repair. It will b anothr item next...Tv wears out like a computer or fone
tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
2answers
Samsung Plazma TV suddenly went sepia after loud bang. Can someone help please?
You may have found the source of the loud bang. Time to turn it over to a repair technician.
Can i het code for Samsung using a goldstone gs 32lcd
For easier access, the model code and the serial number of the TVs are located on the right side of it. For older models, you will find the model code and serial number at the back of the TV
https://www.samsung.com/pk/support/tv-audio-video/how-can-we-find-the-serial-number-and-model-of-samsung-tv/
I need to know if tcon brd t400xw01 v5 crt1 bd 40t01 -c00 will work in samsung la40a450 c1 dxxy ver no aco3
none of these model number are correct. the model number and serial number and version numbers will be on a separate sticker toward the side. the correct model and version number will have to be supplied to get a correct answer. the model number will be called model code. I is very long.
All my tv stations are mixed up and not on the right channels.ie,itv one is on channel 59.model code of tv is ps51d495a1kxxu.serial number isb2td34pb804100n version 02 d495a1kxxu
I would try resetting the TV to it's factory setting. Look it up in the manual. Then rescan the channels. If that does not work you might have a bad signal board.
you can get parts for this tv at www.interliquidparts.com
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
14helpful
How do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
version..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
About the color wheel option
Hello Brandon B,
look on the side of the unit there will be a sticker with Model number, serial number and Version code. The version code will tell me what color wheel you need. There maybe some CCA adjustment you need to do using the remote in Service mode. Let me know what the version number. We will go from there. You can contact www.interactiverepair.com they will walk you through the installation process
Best regards
circuitcity
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
