My 32lc5dc is in hotel mode and won't unlock I've tried everything
  • Tanuja Jan 13, 2019
    Lg 32lc50c is in hotel mode how to unlock
  • 315 Answers
Its a long shot but if you could get into the menu, select lock and try code 1105 it might unlock it, it might not.
However, some hotel TV's have a different main pcb, to stop them be worth anything if stolen.
Posted on Aug 25, 2016
2 Suggested Answers
gopakumarg43
  • 76016 Answers
SOURCE: how do I unlock it yes visualax LCD /tv LTV263HD-SII locked in hotel mode
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Posted on May 22, 2015
Stuck in hotel mode
The pin is 9876, ENTER. The zeros won't change while you input the code.
May 16, 2015 | LG 32LC5DC 32 in. LCD HDTV
I am at a hotel for a couple months. There is an lg 32lc5dc for a tv. There is no box to order movies but I can not use the hdmi port. There is audio but no video. The hdmi 2 port does not work at all...
probably the tv is hotel mode ,which is the management or tech have lock the sys ,to avoid complication for guest ,u have to find the manual or through on line.
Oct 05, 2013 | Televison & Video
We use the Mitel 5212 IP phones for our hotel. We are trying to find a way to retrieve a previous voice message from a previous guest that stayed with us. How should I go about finding this information?...
If you're using the embedded voicemail, you won't be able to retrieve such messages. If you're using another, external, voicemail system, then it might be possible.
Every hotel I've ever installed, I've left hotel admin guides for the voicemail. This information should be in such a guide if your vendor is any decent.
To find out what sort of voicemail you've got, you should contact your vendor.
Sincerely,
Mark
May 12, 2011 | Mitel 5212 IP Phone
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
I need to reset i dont know the code
please post it here if you do find it. thanks.
someone stated this
noavatar_s.gif Dish Fitter
Rank: Master
Rating: 70%, 17 votes
Press MENU for approx 5 seconds then enter, 1105 this will bring up the LG2.gif hidden menu then disable the hotel mode option.
Hope this helps
Cheers
Apr 06, 2009 | LG 32LC5DC 32 in. LCD HDTV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Televison & Video Logo
558 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
