Penny, printer streaks on scan or copy. Check the attached links,instruction and guides on how to improve scan and copy issues, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why does my brand new HP Officejet 5740 have extremely poor quality scan...
HP ENVY 5640 5660 7640 and Officejet 5740 8040 Printers Fixing Print...
Fixing Streaks and Lines in Scans Copies and Faxes HP Officejet Pro 8600...
HP Officejet 5740 All in One Printer Troubleshooting
The glass is smudged or dirty or the scanner bar may have dirt on it. Cheaper to just replace the machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
First you need to determine if it's doing from both the top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
