I have a Samsung washer, WF337AAR/XAA and error code bE. I had this before a few years ago and it was the motor speed sensor. Is this part available to buy and is it hard to replace?
If all of the water has been drained from the washer, check the hose to the water level sensor is not plugged. You can find information on the nd error code here
That's probably a t E (error) tE Temperature Sensor Error Power off the washer. After 1 minute, restore power and restart the cycle. If the code returns, service is required. (if this doesn't reset it, unplug the washer for 1 minute)
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
