SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
SOURCE: Washer keeps pausing
you may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
SOURCE: washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Hello friend, thank you for the post!
I understand that your Frigidaire washer, ATF6000es, keeps pausing during a cycle. Generally that means there is a disruption in the cycle. I would try resetting your appliance, unplug the power cord or flip the household circuit breaker, for ten minutes. If that does not resolve the issue it could be a problem with your control board or wiring harness within the washer. I would recommend having a technician come out to the home to diagnose and repair the appliance. Hope this is helpful. -Matt
