It does not show any error codes, over 2 lac copies made, Imaging unit with Drum and Developer powder changed at 1,30,000 copies. Copy quality great
Does it get jammed from draw #2? does a4 jam in tray 1 and by pass
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
SOURCE: Konica Minolta dirty copies
If your dropping toner your losing bias on your Image Unit. You will probably need a new unit.
SOURCE: my konica minolta bizhub 7145
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
SOURCE: Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
