On my oven it was the child safety. Hold the plus button for 5 seconds.
Thank you!
Didn’t work powers off and back on then pressed the plus button for 5 seconds and it worked
Thank you this worked
It happened to mine too and it was the child lock! Pressing + for over 5 seconds sorted it.
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
SOURCE: On my GE electric range
Hi
Thanks for using FixYa. From what you have described it seems to be an oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the electronic control that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
This worked for me too, thank you!
Spot on thank you
