SOURCE: Miele G575
This sounds like the overflow trip switch has been activated. Some time back I had this problem with a Miele G664. The service man undid 4 screws on the door and removed front panel and found water in the drip tray, He then checked the pipes, outlet pipe had a pice of plastic bread tag stuck in it , this was slowing down the time it took to empty the water and the next fill made it overflow and switch off the dishwasher. He cleaned out the chanel on the overflow that was full of dust and fluff checked the levels to make sure the dishwasher was sitting true. Closed it all up and ran the dishwasher. Perfect!
Bill $160. It did take him the best part of an hour and I live a long way out of town.
SOURCE: What kind and how much salt goes into my miele
Straightforward, coarse, dishwasher salt (sodium chloride). Regular table salt is far more expensive and because it's not coarse it clogs when pouring it in.
Just pour salt into the salt chamber until it's full and screw the lid back on.
SOURCE: water levil to high on
It is possible that there is a block in the drain hose which prevents water from previous wash to fully empty.
This means when you start dishwasher next time it overflows and causes the dishwasher flood switch to trip and shut dishwasher.
You will need to check the drain hose for any blockages and clear it.
SOURCE: miele G575 Dishwasher
If the water level is not adjusted at the right level
(see Miele G 575 manual page 29),
the flap doesn't open at the right circle,or doesn't open at all.
(Cause of the low water level the machine makes more noise!)
======Now shut down the power for the machine!!!=============
To adjust the water level new,you have to open the shield(2 screws) under the
main door.(enginen compartment).(You don't have to move the machine!)
On the right ,right,right,hand side,there is a 6 cm round beige plastic box.
(the first thing you see to you right and very easy access)
Only one black water hose(about 1cm=1/4inch) and a few wires are going into this box.
This is the water level adjustment box.
In the middle of the beige plastic box is a beige plastic screw
to adjust the water level new.Turning it clock vise ,increasing
the water level.
(For the right water level,see page 29 in your G575 Miele manual)
The water level hasn't to be super price.Just in about and enough.
(It seems that the rubber membrane in the water level unit ages
and therefor it has to be readjusted after a longer time)
SOURCE: My g575 miele dishwasher will not fill with water until the end of the dry cycle.. help
see this possible fault:Water-inlet valve
the valve is defective, test and replace it see how.
Float switch
had been fail, replace see how to test it, and see the diagram
