Mitsubishi air condition timer light 6 times blinking.n there is no cooling
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
Testimonial: "After to days. It's to late answer."
After 10days u give answer. It's too late.
6 time timer lite blink what is problum pleaae answer my q please mem
Timer lamp 6 time blinking Mitsubishi inverter AC heavy
SOURCE: plentiun air conditioning coils are icing up after
Ice forming can be the results of dirty filter, dirty coil, low refrigerant charge.
SOURCE: Operation light and timer light blink 5 times?
If it's winter, you may need to get rid of ice built-up inside that's keeping the fan from turning. Turn the power off AT THE FUSE BOX, open the top of the unit by removing the 4 screws, pour boiling water onto any ice at the bottom until melting, dry with hair dryer a bit, then turn unit back on.
SOURCE: WHEN I START A.C. ITS OPERATION AND TIMER LIGHTS STARTS BLINKING AND N OT COOLING
Sounds like a pressure switch may have it shut down. It could be the main circuit board but not likely. Its in the control circuit and will need to be troubleshot
SOURCE: why my mitsubishi air con blinking 6 times ?
that is only half the code you need the remote an lots more steps to troubleshoot that conditioner
here is some simple steps . but id get help on this.
http://www.daikin.com/products/ac/services/troubleshooting/
after that comes this step an its exacting
AstiquerMold Control Air con Specialist
in that page at the top is the command for your unit to ask it what code its tossing.
