Televison & Video Logo
R
Robert Loer Posted on May 13, 2016
How do I fix my LCD TV?
Model # 42LB5600-UZ Audio but no picture. Followed tips from shopjimmy.com and other sources. Found all LED's out. If TV is allowed to sit picture will come back but LED's go out on 30 seconds to 5 minutes. Replaced power supply/LED power board. Same problem. Found out put for LED's and measured 124 volts DC. When lights go out voltage is 0. TV only has 2 other boards if I understand correctly, main board and the small tcon board (I think that is the term). Do I next replace the main board? If Leds were bad wouldn't I still have voltage?
Tom Russo
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 12, 2016
Tom Russo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
524
Points
If you hold a flashlight up to the screen do you see any image or video
5 Related Answers
Anonymous
  • 14553 Answers
  • Posted on May 17, 2012
SOURCE: AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
CoppellTVRepair.com
  • 778 Answers
  • Posted on Apr 25, 2013
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Charlie F
  • 56 Answers
  • Posted on Jan 03, 2015
SOURCE: I have a VIZIO VW32LHDTV20A tv I have audio comes on and stays on like it should but no video the back lights are on.
LCD simple panel check. In a dark room, (does not have to be total), shine a flashlight at it with a station tuned in. If you see images
and you have changed the panel HV board, your flourescent tubes could be bad. If you dont, then check the cabling.
Testimonial: "The back lights are on just video on the panel tv turns on and off as it should just not picture."
gopakumarg43
  • 76851 Answers
  • Posted on Mar 28, 2015
SOURCE: What is the AC voltage input range of the power supply board. I think it is 110-240 volts. Please advise. For immediate reference, please see the image of the power supply board by clicking http://as
110 > 240VAC is the input voltage. Auto select by the regulator board inside. Electro help
gopakumarg43
  • 76851 Answers
  • Posted on Sep 02, 2015
SOURCE: 70in vizio has no picture but has sound. I replaced the tcon board and the picture came back for about 5 seconds but faded out. Is the tcon board bad again?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
2answers
Westinghouse tx-47f430s LCD TV...Picture Solarized
Shop Jimmy is the place for all the spares
ShopJimmy: TV Parts, Universal TV Stands, TV Repair
https://www.shopjimmy.com
The online leader in TV repair, replacement TV parts, DLP lamps, Universal TV Stands, LED Strips & more! Fix your LCD, LED, Plasma or DLP TV today!
TV Parts
Shop our replacement TV parts to repair your TV today!
But have a read of this tip I wrote.
https://www.fixya.com/support/r29790007-repairing_own_television
Lg model 42lb5600-uz sometimes comes on for 5 seconds then picture goes black with sound
The tv that I have is an LG 42LB5600-UZ, but that wasn't one of the choices. The problem is that the television turns on... has a picture and sound, and then in about 30 seconds, the screen goes black but the sound continues. It is the same on every channel. It worked fine last night, but not today.
I have a LG 42LB5600-UZ LED TV my red power light comes on but when i press the power button no picture or sound comes on i need help with this one
If you wish to get some details; visit the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by mobile or a desktop to see the search box. Mobile view has no search box.}/
Have a 42LB5600-uz with lines in it vertical. Changed the T-CONN Board. What to do next.
Main board is bad, on this model its almost never a tcon board issue its the main..you can try cooking the board in the oven as this does fix it about half the time or replace the board, shopjimmy seldom has this board in stock so you may have to go to ebay although I don't reccomend ebay for boards as a lot of the ones sold aren't any good.
Repair An LG Television Motherboard By Baking It In The Oven
Led driver on lg led tv. Is the driver bad or the led light strip bad
Only way to find out is to take the panel apart and test the LED strips with a DC power supply
1helpful
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
How to fix vizio tv that turns on but no picture
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
