Dragon Touch Touch R10 10.1 Google Android 4.1 Dual Core Tablet MID PC, Rockchip RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, Multi-Touch Screen, Front Camera Rear Camera, Google Play Pre-Installed, HDMI Logo
Carla Ducena Posted on May 11, 2016
Wifi antenna is in the halway and when i enter my room SWOOSH WIFI IS GONE
HOW CAN I FIX THIS PROBLEM
Phil Potter
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on May 11, 2016
Phil Potter
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
13860
Points
59
There are multiple fixes for this...but the easiest is an extension antenna.
My Polaroid P9 tablet will not connect to my wifi.
Try it near your router when connecting to WiFi
Tablet doesn't pick up WiFi in other rooms. What can be done about that?
Move tour wifi router to a different location, upgrade your router to one with better range or purchase a wifi extender. Most routers have a rang of about 100ft. Better ones can reach as much as 3 to 400 feet.
Problems with wifi staying connected and sitting right in front of wifi modem
They all say, for best results, don't set less than 3 ft. from the Wifi antenna.
3answers
Why Tablet Wont stay connected to wifi?
this may be because they wifi goes away and comes back again. or maybe because it's messed up .
hope this helps.
I cannot connect to my home wifi I am sitting across the room from my router and have entered the id# and network key. it will show the network with a singnal and then says Not In Range. I am not 5 feet...
that coby kyros are one of the defective tablet opens in market because of the wifi connection. but i got another solution in that! to open, mail me or add me on the facebook to teach you how to open that wifi @ [email protected] or search me on facebook ronald c delos santos
I have bought a patch lead to connect my ipad to an external antennae. The patch lead has a stick on base to attach to the ipad. What would be the best location on the ipad to attach the base? Thanks for...
To be perfectly honest, I'm pretty sure you can't just fix an antennae onto an iPad and expect to get better signal. RF antenna are highly complicated things that are finely tuned. The iPads' WiFi antenna is behind it's black Apple logo, and if you have a 3G iPad the 3G antenna is inside the little black bar at the top of the back of the iPad. You could have a go at attaching your cable on there, but I very much doubt it's going to have much of an effect.
Hope that helps, good luck!
The kindle's signal strength is not strong once I leave the room where the wireless router is. Shouldn't I be able to use this device in other rooms of my house?
Wireless reception can be negatively affected by a number of circumstances. I can give you a list of things to look out for but no definite solution without having more information about your wireless router, the set up of your house and other factors.
  • Place your wireless router in an elevated position and have the antenna stand upright. Keep it at distance from other machinery, metal decoration or containers filled with water. Metal scatters the radio signal of the router, water absorbs it, both is most unwanted.
  • Drywall (aka plasterboard or gypsum board) is used in house interior as wall covers. Despite its name, it contains plenty of chemically bound water. Therefore, drywall is notorious for blocking the WiFi radio waves. The same applies to armed concrete walls.
  • Some electrical appliances (e.g. many microwave ovens) knock out WiFi signals in their vicinity. The kitchen therefore is no good place for a router.
  • Modern wireless routers use MIMO antenna set-ups, greatly extending range and signal quality. If your router has one antenna only, consider exchanging it for a model with three or more antennas (Netgear RangeMax or Linksys SRX models, for example).
Please add a comment to this solution if you do not feel any of the above applies to you, give some more information and I'll try to fill you in more.
Top Dragon Touch Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you a Dragon Touch Tablet and eReader Expert? Answer questions, earn points and help others
