LG 42LG50 42-Inch 1080p LCD HDTV Logo
Francine Byron Posted on May 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It shuts off 2 seconds after i power on.
I power on it clicks the screen flashes and then it clicks and powers off
Donald Ayers-Marsh
Level 3:
  • Master 1,389 Answers
  • Posted on May 06, 2016
Donald Ayers-Marsh
Master
Level 3:
Answers
1389
Questions
0
Helped
559821
Points
6679
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
How do I select a Casio g-shock from chirping every 60 seconds//
Question moved from Sharp Televisions to Casio Watch.
Every 60 seconds or every 60 minutes? Do you see 'PS' for low power, power saving on the screen. How new is the battery?
https://www.google.com/search?q=Casio+g-shock%2C+chirping+every+60+seconds
1helpful
9answers
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 • Watches
1helpful
Any way to stop the intermittent screen flashing for my Sony kv-32S42?
Is the unit plugged directly into a wall AC plug?
Are you using a power strip?
Have you changed any settings either on the unit itself or on the original remote or are you using a different remote?
Are there any other high voltage units connected to the same wiring?
Aug 20, 2018 • The Watches
1helpful
3answers
How to set led watch
What make and model of watch is this?
Sep 08, 2011 • Watches
9helpful
Set time on TIMEX 1441 sports watch
To set your watch:
1. Press the top left button while the screen shows the time. The seconds should begin to flash on the screen. 2. Press the bottom left button to switch between seconds, minutes, etc. 3. To increase a number press the bottom right button 4. Press the top left button to stop changing/confirm the time you have set.
This is the general way to set most watches
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 • Watches
62helpful
13answers
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 • Watches
198helpful
6answers
How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Dec 20, 2007 • Watches
Top LG Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LG Watch Expert? Answer questions, earn points and help others
