This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
- Unplug the washer or disconnect the power for one minute.
- Plug in the washer or reconnect the power.
- Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
