It only print out this report "INTERNAL ERROR- Undefined Command" Position: 0x0 (0) LINE :277 VERSION: SPL 5.40 03-10-2010 Model Name : SCX-3200 Series Machine serial: Z510BFBB800438F Firmware version: V3.00.01.08F oct-18-2010 please help if any solution to fix this matter?
SOURCE: CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
SOURCE: SPL-C ERROR with Samsung CLX-3160 FN when printing from iMac
This can be fixed by stretching out a solenoid spring on the power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot. The picture below is from a Samsung CLP-300 but these both use the same Imaging Unit so this should work. It's just a little more involved taking off the top scanner / buttonpad off the CLX-3160.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
SOURCE: "Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
Have a nice day!
