The Error indicates that the water level did not increase or fill in time to the machines estimation .
4E
WATER SUPPLY ERROR
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Check that the water valves are fully open check that any fill lines that have washer hose filters in them are clean check you source water pressure is OK
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
SOURCE: 4E showing on Samsung Washing Machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: my 5kg samsung top washer
Hi Error 4E in your Samsung Top load means that the water in
unable to enter the machine. Please clean the water hose as there might be a
blockage at the end of the hose where it fits in the drum. After cleaning if
the issue remains then you'll have to replace the inlet hose with a new one. Hope
this helps...please post back for further assistance. Daniel
Display shows 4E.
