The water Supply
1. First, check that the tap is not accidentally turned off.
2. Check that the gray water inlet hose is not squashed or kinked lies.
3. It is also possible that the filter is clogged in the supply hose. Close the tap and disconnect the hose. Here is some pressure on it, so keep a towel handy. Check the filter that output waterklraan, and clean it if necessary.
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
SOURCE: About mid cycle, a significant amount of water
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
SOURCE: AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
