RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Sonya Thomas Posted on Apr 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv the on off button is blinks 3 time the does nothing
Is there any other way of getting it to turn on other than changing the resisters way in the front i got it to turn on the other day by turning the on of button on & off really fast
David Payne
Level 3:
Top Expert:
  • RCA Master 14,162 Answers
  • Posted on Apr 02, 2016
David Payne
RCA Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2995840
Points
455836
Level 3:
  • RCA Master 19,187 Answers
RCA Master
Level 3:
Answers
19187
Questions
0
Helped
4341398
Points
82259
This sounds like a component failure in the power supply board. You can order a new one or have it serviced.
2answers
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Turn tv on tv nothing happend red light blinks 3
O would need the model number to assist you, as the s blinks is an error code, but error codes are model specific.
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
1helpful
2answers
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Power up
the error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
