Machine works fine until spin cycle when starting it klunks and bangs then settles and then spins ok
SOURCE: off balance during spin cycle
I have a Performa Model PAV3200AWW that would go unbalanced every time it would go into a spin cycle. I found the problem to be a worn out snubber. This is a plastic ring that is at the pivot point for the whole tub. It separates the metal to metal contact at the bottom of the washer pivot point. The part is less than ten dollars, but it is a quit a job to replace. I had to remove the whole tub to replace mine, but it did solve the problem. If you see a lot of plastic shavings around the pivot point, then this could be your problem.
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
SOURCE: banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
SOURCE: Washer is always "out of Balance" during the spin cycle
Way to go. A+ to you. Good Luck in future.
