SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal
hardware error.
Recommended Action
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: hp laserjet 3055 has code 52 scanner error
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
SOURCE: hp laserjet m1522nf 52 scanner error
Step 1.Switch on the machine observe Optical scanner assm moving forward & reverse for checking home position? remove flat bed glass,clean it especially at black band area, fix it and check..Step 2. Switch off the machine, remove power cable, remove left side door,dis connect Scanner cable(connector J4) on formatter, switch on the machine, check if same error? replace formatter assm..if different error replace optical scanner(CCD) assm..
SOURCE: HOW TO FIX SCANNER ERROR 52 HP LASERJET M1212NF
Possible that a reset might help. It is worth trying to re-install.Shut down PC system and restart with the printer removed , then install the driver software and on completion connect the printer-hardware- to be installed.Test and see if it works or else you might need help from HP support.Check this link : http://www8.hp.com/uk/en/support-drivers.html
