Whirlpool Duet GHW9150P Front Load Washer Logo
J
Jean Fields Posted on Mar 05, 2016
How to place the rack for washing tennis shoes?
1 Related Answer
Anonymous
  • 170 Answers
  • Posted on Mar 21, 2011
SOURCE: i washed 3 pairs of
I have post on here to get front load door open//click on my name..good luck
A pair of running shoes costs $5.00 more than a pair of regular tennis shoes. The total cost for both is $115 Find the price of the regular tennis shoes
You will never learn any mathematics if you do not solve math problems. I am here to do your homework. I will however help you set the problem up.
1. Define variables (unknowns).
2. Let t be the price of the tennis shoes
3. Let r be the price of running shoes.
Translate the text into mathematical expressions
A pair of running shoes costs 5$ more than a pair of tennis shoes
5 $ more ---> ... +5
Cost of a pair of running shoes (r) = cost of a pair of tennis shoes (t) +5
So the first statement can be expressed as r=t+5
The total cost of both ------> Sum of the costs r+t
The total cost of both is 115 $ ------> r+t=115
Now you have a system of two linear equations in two unknowns
( r=t+5
(r+t=115
There are a few methods to solve the system (comparison, substitution, or combination/addition/elimination). I gave the 3 possible names for the third methods.
Choose a method and solve the system to find t and r.
Note: Although all three methods, if carried out correctly, will give you the same solution (t,r), one of them should be preferred. It is worthwhile to recognize immediately which method should be favored depending on the system you are dealing with.
tip
Removing stains from tennis shoes.Most modern tennis shoes are made out of...
removing stains from tennis shoes.Most modern tennis shoes are made out of easy-to-clean material, and can be cleaned off with warm water, soap, and some scrubbing. More soiled shoes can be cleaned with a commercial cleaning solution. Bleach and glycerin can also make a good shoe-cleaning substances if mixed correctly
on Oct 27, 2010 • Clothing Accessories
How do I use the dryer rack?
The dryer rack is used for laying out clothing that you don't want to get tossed around. Example: Sweater or tennis shoes. It sits in a groove behind front door and sits in groove at back of tub.
3helpful
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
Our Maytag Performa washing machine began making a loud noise similar to a tennis shoe banging in the inside. Now it won't spin. Could it be the belt?
I think there is more of a problem than just a belt,If you have been actually washing shoes in there then there might be a problem with the gearbox.
Dryer won't start. was drying a load and had a pair of tennis shoes in with the clothes. It stopped and now won't start back up. All lights, beeps etc. seem to work fine just won't start.
As silly as this seems, did you make sure the door is completely closed. This is a common problem when drying tennis shoes. One time when I was living in an apt. complex, I went to check on my laundry, and my shoes were lying on the floor (with a couple of other fabrics). I then stood by and watched the remainder of the cycle, and next thing you know - the door opens up and throws out my shoes. Never would've believed it unless I seen it with my own eyes. I would turn everything off, and then go through your regular routine. If this doesn't work, feel free to contact me - and we can go to Plan B...:) Good Luck to you, Jim
1helpful
I wanted to know how to wash tennis shoes?
some machines have a tray that installs inside to wash shoes. If yours does not, then you can place each shoe in a stocking or large sock - wash on gentle cycle - low heat. NO bleach.
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Replacing stabilizers
well if you have a top loader then one or more of these bungies have broken: 8a74703.jpgIf you have front loaders then a stablizer is like a shock on a car, with any luck you just have to locate it and snap it back in place. They come loose when someone washs tennis shoes or the washer is simply moved to another location.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
21helpful
3answers
Dryer rack installation
I had the same problem: they sent me the rack, but no instructions.
But if you look in the product manual for your dryer, there should be a section on how to use the rack. For the Cabrio, which is what I have, it's on page 21.
If you don't have the manual anymore, you can get them online at Whirlpool's web site. Just plug in your model number in the search box, and there it will be.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
