Kenmore 43142 Front Load Washer Logo
A
Anonymous Posted on Feb 27, 2016
Our front loading washer won't agitate model #417.43142200
The washer will fill, drain and spin, but not agitate. It seems to be running through the wash cycle slower than normal and seems to sit in this cycle for three times longer than usual. Is this something I can fix myself?
5 Related Answers
Anonymous
  • 145 Answers
  • Posted on Dec 27, 2008
SOURCE: Kenmore Washer 110.26912690 series 90
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
Anonymous
  • 20 Answers
  • Posted on Jan 19, 2009
SOURCE: Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Jan 24, 2009
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
tzweeb
Tom Zwiebel
  • 318 Answers
  • Posted on Jan 31, 2009
SOURCE: Kenmore 70 series Heavy Duty washer model 110.82872100
you probably have a bad or burnt contact in the timer. it could have had bugs get into it during the storage. it does happen. a new timer could cost 120-150 bucks and i dont think you will have much luck with an over 20 year old washer. if you did replace the timer then what would be the next thing to fail?
save your money and go out and buy a new roper or whirlpool built unit. roper is the cheaper version from whirlpool and has the exact same parts.
you can find a new unit for about 275-300 bucks. it will be a much better choice for you in the long run.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 02, 2009
SOURCE: washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
My midea steam front load washer won't wash or spin
Hi Lynn.
you can try a Master Reset. This will reset all of the onboard componentry and is often successfully used by appliance technicians. Open and close the door of the washing machine 6 times within 12 seconds. Then, run the rinse/spin cycle without clothing to see if your problems are resolved.
or go to this link might help you out and scroll down the page.
https://www.google.com/search?client=avast-a-1&q=midea+steam+front+load+washer+won%27t+wash+or+spin&oq=midea+steam+front+load+washer+won%27t+wash+or+spin&aqs=avast.0.69i59.10j0j1&ie=UTF-8
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Washer will not spin nor agitate
mj, sounds like a broken coupler, look at number 13 on the picture. The fact that it won't agitate or spin but will drain rules out the lid switch. This is not a hard job. Check this out first. Catriver..post back
Alexander
vince
