Question about Bella High Power Juice Extractor
I need new blade - Bella High Power Juice Extractor
    Top Expert:
  • Bella Master
  • 57,204 Answers
Sorry we do not sell blades here , try the manufacturer
Posted on Feb 25, 2016
Nutri-max. Where can I get blades and a filter?
Check with a local appliance parts supplier
Feb 23, 2016 | Juicers
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
I need a cutter blade parts no 015180. Can I pay for it on the net?
You can buy it from Waring or Omega, same blade.
Or, just google Acme juicer parts. $20 to $30. Look
out though, found new blade increases vibration. You
can also sharpen old blade by slightly drilling into
each burr on the blade with a small drill bit. Been
using the same blade for several years.
Jan 28, 2011 | Acme 6001 Juice Extractor
Excessive vibration and rattling when I have less than a cup of juice extracted.
I've had an Acme for 21 years and I don't care
what anyone tells you-they vibrate. After years
of trial and error I found mine vibrates less with
a worn blade that I sharpen with a drill. With
a new shredder blade you actually have to file
down the cutting burrs about one third and
adjust the blade to chute gap by unlocking
the adjusting screw on the center of the bottom,
turn it clockwise until blade contacts chute, and
back it off a half turn. Apparently with a slightly
duller blade, smaller gap, the produce goes through
more slowly and evenly. Also severe vibration will
cause the blade to jump up and chip the chute.
Dec 24, 2010 | Acme 5001 Supreme Juicerator Juice...
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Vibration
DIFFICULT TO USE. SHOULD HAVE GONE
FOR THE 4000 WHICH EJECTS THE PULP.
SOMETIMES THE BLADE JUMPS UP AND
CUTS THE BOTTOM OF THE CHUTE IN-
CREASING THE GAP BETWEEN THE BLADE
AND CHUTE BOTTOM. INSPECT AND I YOU
NEED A NEW COVER CALL OMEGA AT 717
561 1105.
Oct 01, 2008 | Omega 1000 Juice Extractor
Where can we locate a parts store?
The cutting blade can be found at http://www.waringproducts.com/ret/.  Waring now makes the juicers.  Good luck!
Mar 11, 2008 | Juicers
Screw that holds down the blade in cwnter
try here, not sure if it's listed or not though: http://www.healthnutalternatives.com/acme5001.htm
Sep 02, 2007 | Acme 5001 Supreme Juicerator Juice...
Bella High Power Juice Extractor Logo
636 people viewed this question
Top Bella Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Bella Juicer Expert? Answer questions, earn points and help others
