It is a mountain bike frame. That's all I know.
SOURCE: I have an old cruiser bicycle. I don't know what
Any major bicycle shop will have an assortment of fenders in various shapes and sizes.
Ed
SOURCE: how to know a genuine cinelli mountain bike frame
I just took a look at mine, which is a 1990 "The Machine" model, and the easiest way I can tell you they although they are made with round Columbus tubing that has been FLATTENED on the sides of the top tube and the down tube where it joins the steer tube giving the tube more of an oval shape. The top tube is also flattened on the top and bottom where it joins the seat tube lug. I don't recall anyone else doing this. Mike.
SOURCE: bicycle brand name
Does it have to be an original part? Most any parts on a bicycle are interchangable with other bikes.....good luck with it.
SOURCE: How do I pump a
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
