Daewoo Baumatic Fridge Freezer Fan Motor 3015915900 Logo
Sue Hannon Posted on Feb 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The deodoriser & fuzzy lights are alarming & sometimes the light goes out. the fridge door doesn't seem to be closing properly?
brian dawson
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 05, 2023
brian dawson
Contributor
Level 1:
Answers
Questions
0
Helped
3034
Points
7
Fuzzy light on freezer starting to defrost
Ken Wieczorek
Level 2:
Sergeant:
  • Daewoo Expert 451 Answers
  • Posted on Mar 02, 2017
Ken Wieczorek
Daewoo Expert
Level 2:
Sergeant:
Answers
451
Questions
0
Helped
228073
Points
825
Need more info Model # door not closing will cause all kind of problems
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
The open door alarm goes off when the door is closed
THE CONTACT INSIDE THE FRIDGE THAT THE DOOR MAKES CONTACT WITH MAY HAVE DIRT OR SOMETHING ON IT,IF IT DONT MAKE GOOD CONECTION WHEN CLOSED THE LIGHT WILL STAY ON AND THE ALARM STILL CARRY ON GOING OFF.ALSO CHECK THAT THE LEVER INSIDE PUSHIES IN AND OUT AND NOTHINGS BLOCKING IT.ROB
5helpful
2answers
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
1helpful
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 • Freezers
2helpful
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 • Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Top Daewoo Freezers Experts
ADMIN Andrew
ADMIN Andrew
Ismail Soomro
Ismail Soomro
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
