Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
Correction! Processing Data LED remains Green and Error LED remains Red.
COPY, FAX and SCAN LED remains ON with GREEN color.
Vinay Shah mine is doing the same thing
