Timex 1440 Nylon watch Logo
melvin Reid Posted on Feb 01, 2016
Instructions to set time - Timex 1440 Nylon watch
How do i set time on the watch as I lost the instructions and had a new battery put in and I don't know how to set the time
Best answer, Google the make/brand of the watch. The makers usually put pdf instructions online. Or youtube is always a good idea
Aug 30, 2016 • The Watches
How to set the indian standard time in this watch
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
If you cannot find the caliber number for your watch, enter the example number (E810) and you will find instructions for settiing th local time.
Time setting instructions missing
Go to http://www.nike.com/timing/ choose your region and click on "support".
In the menu on the left is a box called "All manuals"; Scroll down until you reach your model and download yior instructions.
2answers
Need help setting time etc on my pro spirit watch from Target
I searched for instructions for you watch but was unable to fins them. If you follow the instructions below, you may (with some experimenting) be able to set your watch.
There should be a button marked "mode". Pressing this button cycles the display through the various setting options that are available on the watch.
The functions are likely to be abbreviated, so you may have to guess what each one means.
When you have reached the time setting mode (TS perhaps?) use one of the other buttons to advance or ****** to time etc.
Good luck.
Feb 20, 2010 • Watches
Setting time and date for Citizen BT0010 54E
Use this link: http://www.citizenwatch.com/COA/English/settings.asp Fill in requested details of your watch and click on GET SETTING INSTRUCTIONS, then click on INTERACTIVE SETTING INSTRUCTIONS. There you will find everything you need to set up your watch. You can download instructions on this site as well.
Rate me, please.
5helpful
Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
2helpful
Instructions for casio wave ceptor 4303
Managed to set the home time - through trial and error.
Left it at the window for a few minutes and VOILA - the watch did the rest.
MAGIC!
It keeps time perfectly.
16helpful
Instructions
i have a CL-5073
to set time:
HOLD "Set" for 3 seconds
then use "Mode" to browse through option
When you get the time setting hit "St/Sp" to set the time
When you're done press "Set"
hope this helps
3helpful
2answers
Operating instructions for BL5184-56L
Try this link and pay special attention on how to find your particular watch movement.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
